/PLOAD
Block Format Keyword Defines pressure load on a surface.
/PLOAD/pload_ID/unit_ID | |||||||||
pload_title | |||||||||
surf_ID | fct_IDT | sens_ID | Idel | Ascalex | Fscaley |
Definition
pload_ID | Pressure load block
identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
pload_title | Pressure load block
title. (Character, maximum 100 characters) |
surf_ID | Surface
identifier. (Integer) |
fct_IDT | Time function
sens_ID | Sensor identifier.
(Integer) |
Idel | Pressure canceling flag.
(Integer) |
Ascalex | Abscissa (time) scale
factor. Default = 1.0 (Real) |
Fscaley | Ordinate (pressure) scale
- In 3D analysis, positive pressure acts in direction with N1, N2, N3, and N4 being the nodes of the segment in the surface definition.
- In 2D analysis, positive pressure acts in direction normal to N1 and N2, obtained by a rotation in the counterclockwise direction.
- The
Ascalex and
Fscaley are used to scale
the abscissa (time) and ordinate (pressure).The actual pressure function value is calculated as:
(1) Where, is the function of fct_IDT.
