/GRAV
Block Format Keyword Defines gravity load on node group.
| /GRAV/grav_ID/unit_ID | |||||||||
| grav_title | |||||||||
| fct_IDT | Dir | skew_ID | sens_ID | grnd_ID | Ascalex | FscaleY | |||
Definition
| grav_ID | Gravity load block
identifier. (Integer, maximum 10 digits) |
| unit_ID | (Optional) Unit identifier. (Integer, maximum 10 digits) |
| grav_title | Gravity load block
title. (Character, maximum 100 characters) |
| fct_IDT | Time function identifier.
3
(Integer) |
| Dir | Direction in translation
(input should be: X, Y or Z). Default = Z (Text) |
| skew_ID | Skew
identifier. (Integer) |
| sens_ID | Sensor identifier.
(Integer) |
| grnd_ID | Node group to which the
gravity load is applied. Default = 0 (See Comment 2) (Integer) |
| Ascalex | Abscissa (time) scale
factor. Default = 1.0 (Real) |
| FscaleY | If
fct_IDT =
0: A constant gravity value is applied. If fct_IDT > 0: Ordinate (force) scale factor. Default = 1.0 (Real) |
/UNIT/1
unit for load
# MUNIT LUNIT TUNIT
g mm ms
/INIGRAV/1/1
hydrostatique pressure – sea level : {Z=0} where Pref=0.101325 MPa
#GRPART_ID SURF_ID GRAV_ID
0 0 1
# Pref Bx By Bz
0.101325 0 0 0
/GRAV/1/1
Terrestrial gravity field
#funct_IDT DIR skew_ID sensor_ID grnod_ID Ascale_x Fscale_Y
2 Z 0 0 5 0 -0.00981
/FUNCT/2
unity
# X Y
0 1.0
1000000 1.0
#enddata
- The gravity load direction must be right justified in the ten characters of field number 2.
- By default, the gravity loads are applied to all the nodes in the model. The gravity loads can be applied to a specific group of nodes by defining grnd_ID.
- If function
fct_IDT
=0 or is blank, the gravity load is a constant value
Otherwise, if the function fct_IDT is defined, the actual load function value is calculated as:
Where, is the function of fct_IDT.
/GRAV applies to each node and is stated as force:
With being the mass of node. The node will be moving until a force balance reached.
- If the gravity card is referenced by an /INIGRAV card
for hydrostatic pressure initialization in a fluid-structure interaction
simulation, the applied gravity must be constant be a constant value by defining
FscaleY without
fct_IDT or by referencing a
constant function from t=0 in
fct_IDT.
