/BEM/DAA
Block Format Keyword Doubly Asymptotic Approximation for underwater explosion, where the fluid mass matrix is computed by boundary element method.
/BEM/DAA/daa_ID/unit_ID
daa_title
surf_ID grav_ID
ρ C Pmin
Xs Ys Zs
Iform Ipri Ipres Kform Freesurf Afterflow Integr
Insert if Ipres=1
Pm θ a a θ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGHbWaaS baaSqaaiabeI7aXbqabaaaaa@3A30@
Insert if Ipres=2
fct_IDP FscaleP
Xc Yc Zc
Insert if grav_ID > 0 or Freesurf=2
XA YA ZA
Dir-X Dir-Y Dir-Z
Definition
daa_ID DAA block identifier.
(Integer, maximum 10 digits)
unit_ID (Optional) Unit identifier.
daa_title DAA block title.
surf_ID Wet surface identifier. 2 3
(Integer)
grav_ID /GRAV option identifier.
(Integer)
ρ Fluid density.
(Real)
[ kg m 3 ]
C Fluid sound speed.
(Real)
[ m s ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada Wcaaqaaiaab2gaaeaacaqGZbaaaaGaay5waiaaw2faaaaa@39DE@
Pmin Pressure cutoff (< 0).
Default = -1030 (Real)
[ Pa ]
Xs X-coordinate of standoff point. 3
(Real)
[ m ]
Ys Y-coordinate of standoff point. 3
(Real)
[ m ]
Zs Z-coordinate of standoff point. 3
(Real)
[ m ]
Iform BEM solution flag.
= 1 (Default)
Gauss Integration.
= 2
Analytical integration.
(Integer)
Ipri Printout flag level.
= 1 (Default)
Reduced printout.
= 2
Full printout.
(Integer)
Ipres Pressure loading flag. 6
= 1
Pressure computed as P i ( t ) = P m e t θ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGqbWaaS baaSqaaiaacMgaaeqaaOWaaeWaaeaacaWG0baacaGLOaGaayzkaaGa eyypa0JaamiuamaaBaaaleaacaWGTbaabeaakiaadwgadaahaaWcbe qaaiabgkHiTmaalaaabaGaamiDaaqaaiabeI7aXbaaaaaaaa@43A9@ .
= 2
Input by function.
(Integer)
Kform Analysis flag.
= 1 (Default)
DAA1 formulation
= 2
High frequency
(Integer)
Freesurf Free surface flag. 6
= 1 (Default)
No
= 2
Yes
(Integer)
Afterflow Afterflow computation. 7
= 1
No
= 2 (Default)
Yes
(Integer)
Integr Time integer flag.
= 1
First order
= 2 (Default)
Second order
(Integer)
Pm Maximum pressure. 5
(Real)
[ Pa ]
θ Decay time.
(Real)
[ s ]
a Maximum pressure constant. 5
(Real)
a θ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGHbWaaS baaSqaaiabeI7aXbqabaaaaa@3A30@ Pressure decay time constant. 5
(Real)
fct_IDP Incident pressure function identifier.
(Integer)
FscaleP Ordinate (pressure) scale factor for fct_IDP.
(Real)
[ Pa ]
XC X-coordinate of explosive charge.
(Real)
[ m ]
YC Y-coordinate of explosive charge.
(Real)
[ m ]
ZC Z-coordinate of explosive charge.
(Real)
[ m ]
XA X-coordinate of point A on the free surface.
(Real)
[ m ]
YA Y-coordinate of point A on the free surface.
(Real)
[ m ]
ZA Z-coordinate of point A on the free surface.
(Real)
[ m ]
Dir-X X-component of the normal to the free surface plane.
(Real)
Dir-Y Y-component of the normal to the free surface plane.
(Real)
Dir-Z Z-component of the normal to the free surface plane.
(Real)
  1. The entire structure must be modeled. Symmetric analysis is not supported.
  2. The surface normal n MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWHUbaaaa@385F@ should be pointed into the fluid.
  3. Standoff point defined with (Xs, Ys, Zs) is the location where the incident pressure wave is given at time t=0:
  4. A plane wave can be simulated using a spherical wave and putting the explosive charge far enough away.
  5. Pressure at the standoff point as a function of time is:
    Where,
    P m MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGqbWaaS baaSqaaiaad2gaaeqaaaaa@395B@
    Maximum pressure
    t MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWG0baaaa@3861@
    Time
    θ
    Decay time
    The maximum pressure and decay time can be calculated using:
    P m = K [ W 1 3 R ] a MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGqbWaaS baaSqaaiaad2gaaeqaaOGaeyypa0Jaam4samaadmaabaWaaSaaaeaa caWGxbWaaWbaaSqabeaadaWccaqaaiaaigdaaeaacaaIZaaaaaaaaO qaaiaadkfaaaaacaGLBbGaayzxaaWaaWbaaSqabeaacaWGHbaaaaaa @41C4@
    θ = K θ W 1 3 [ W 1 3 R ] a θ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH4oqCcq GH9aqpcaWGlbWaaSbaaSqaaiabeI7aXbqabaGccaWGxbWaaWbaaSqa beaadaWccaqaaiaaigdaaeaacaaIZaaaaaaakmaadmaabaWaaSaaae aacaWGxbWaaWbaaSqabeaadaWccaqaaiaaigdaaeaacaaIZaaaaaaa aOqaaiaadkfaaaaacaGLBbGaayzxaaWaaWbaaSqabeaacaWGHbWaaS baaWqaaiabeI7aXbqabaaaaaaa@47E9@
    W MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGxbaaaa@3844@
    Explosive mass.
    R MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGsbaaaa@383F@
    Distance to the explosion.
    K MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGlbaaaa@3838@ , α MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqySdegaaa@3792@ , K θ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGlbWaaS baaSqaaiabeI7aXbqabaaaaa@3A1A@ and a θ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGHbWaaS baaSqaaiabeI7aXbqabaaaaa@3A30@
    Constants depending on the explosive.
    If W MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGxbaaaa@3844@ in kg, R MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGsbaaaa@383F@ in meter, P m MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGqbWaaS baaSqaaiaad2gaaeqaaaaa@395B@ in MPa and in ms.
    K MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGlbaaaa@3838@ α MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqySdegaaa@3792@ K θ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGlbWaaS baaSqaaiabeI7aXbqabaaaaa@3A1A@ a θ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGHbWaaS baaSqaaiabeI7aXbqabaaaaa@3A30@
    TNT 52.12 1.180 0.0895 -0.185
    PETN 56.21 1.194 0.0860 -0.257
    HBX 53.51 1.144 0.0920 -0.247
  6. A free surface is a plane defined by a point and its normal vector.
  7. The afterflow normal velocity is calculated as:
    v a f t e r f l o w = cos γ ρ R 0 t P ( t ) d t MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWG2bWaaS baaSqaaiaadggacaWGMbGaamiDaiaadwgacaWGYbGaamOzaiaadYga caWGVbGaam4DaaqabaGccqGH9aqpdaWcaaqaaiGacogacaGGVbGaai 4Caiabeo7aNbqaaiabeg8aYjaadkfaaaWaa8qmaeaacaWGqbWaaeWa aeaacaWG0baacaGLOaGaayzkaaGaamizaiaadshaaSqaaiaaicdaae aacaWG0baaniabgUIiYdaaaa@524C@
    P
    Fluid point.
    C
    Explosive charge point.
    S
    Standoff point.
1 Littlewood, J. de Runtz T. 2004. "USA Code". Mecalog Workshop, Sophia Antipolis, France, 2004
2 Cole, Robert H. Underwater Explosion. Princeton University Press, 1948
