/LOAD/PCYL
Block Format Keyword Defines a pressure load in a cylindrical system on a surface as a function of radius, time and angle of incidence.
| /LOAD/PCYL/pload_ID/unit_ID | |||||||||
| pload_title | |||||||||
| surf_ID | sens_ID | frame_ID | |||||||
| table_ID | Ascale_r | Ascale_t | Fscale_p | ||||||
Definition
| pload_ID | Pressure load block
identifier. (Integer, maximum 10 digits) |
| unit_ID | (Optional) Unit identifier. (Integer, maximum 10 digits) |
| pload_title | Pressure load block
title. (Character, maximum 100 characters) |
| surf_ID | Surface
identifier. (Integer) |
| sens_ID | Sensor identifier.
(Integer) |
| frame_ID | Local frame
/FRAME/MOV identifier to define the axis
of cylindrical system. The local direction X (node_ID1, node_ID2) defines cylindrical axis. (Integer) |
| table_ID | Two dimensions table identifier
defining the pressure function of the radius and
time. (Integer) |
| Ascale_r | Radius scale factor. Default = 1.0 (Real) |
| Ascale_t | Time scale factor. Default = 1.0 (Real) |
| Fscale_p | Ordinate scale factor. Default = 1.0 (Real) |
#RADIOSS STARTER
/UNIT/1
Unit for load
# MUNIT LUNIT TUNIT
g mm ms
/LOAD/PCYL/12/1
laser beam
# surf_ID sens_ID frame_ID
1 0 1
# table_ID xscale_r xscale_t yscale
1 0 0 -0.1
/TABLE/1/1
pressure distribution function of radius and time
#DIMENSION
2
# FCT_ID Time Yscale
2 0.0 0.0
2 0.02 1200.0
2 0.04 2500.0
2 0.06 2700.0
2 0.08 2500.0
2 0.09 1200.0
2 0.11 900.0
2 0.15 400.0
2 0.24 200.0
2 0.31 150.0
/FUNCT/2
Pressure distribution according radius
0 1
.5 1
1 .5
2 .1
#enddata
/END
- This pressure load can be used only for 3D analysis.
- The pressure value is defined with:Where,
- Radius from the cylinder axis.
- Current time.
- Angle between the surface and the cylinder axis.
- The pressure values are not extrapolated beyond the last radius abscissa. The pressure is null outside of the cylinder.
