*LOAD_RIGID_BODY
LS-DYNA Input Interface KeywordDefines a concentrated force or moment applied on main node of a defined rigid body.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *LOAD_RIGID_BODY | |||||||
| PID | DOF | fct_IDT | Fscaley | CID | N1 | N2 | N3 |
Definition
| PID | Rigid component
identifier. (Integer) |
| DOF | Load direction.
(Integer) |
| fct_IDT | Function
| Fscaley | Ordinate scale factor. Default = 1.0 (Real) |
| CID | Coordinate system
| N1 | Node 1 for the local coordinate
system of the follower force of moment (read only for
DOF=4,8). (Integer) |
| N2 | Node 2 for the local coordinate
| N3 | Node 3 for the local coordinate
