*LOAD_SHELL
LS-DYNA Input Interface KeywordDefines pressure load on a single shell element or on a set of shell elements.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*LOAD_SHELL_{OPTION1}_{OPTION2} |
If OPTION1 = ELEMENT (or <blank>)
EID | fct_ID | Fscaley | Tstart |
If OPTION1 = SET
ESID | fct_ID | Fscaley | Tstart |
If OPTION2 = ID
ID | Title |
Definition
OPTION1 |
OPTION2 |
Title | Load
title. (Character) |
EID | Element ID. (Integer) |
ESID | Element set
ID. (Integer) |
fct_ID | Pressure versus time load curve
identifier. (Integer) |
Fscaley | Ordinate (pressure) scale
factor. Default = 1.0 (Real) |
Tstart | Time for pressure activation.
Function fct_ID is shifted by Tstart. Default = 0.0 (Real) |
- This keyword maps to /PLOAD.
