*SECTION_BEAM
LS-DYNA Input Interface KeywordDefines finite element property of beams, trusses, and discrete beams.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *SECTION_BEAM | |||||||
| sec_ID | ELFORM | NIP | CST | SCOOR | |||
If ELFORM = 1, 4 (Integrated
beam element), insert the following line.
| TS1 |
If ELFORM = 2 (Resultant beam element), insert
the following line.
| A | IYY | IZZ | IXX |
If ELFORM = 2, 3 (Resultant beam
element and truss element) with predefined circular section, insert the following
line.
| SECTION_08 | L1 |
element and truss element) with predefined rectangular section, insert the following
line.
| SECTION_11 | L2 | L1 |
If ELFORM = 3 (Truss element), insert the
following line.
| A |
If ELFORM = 6 (Discrete beam element), insert the
following line.
| VOL | INERTIA | CID | AREA |
Definition
| sec_ID | Section identifier. (Integer) |
| ELFORM | Beam element formulation.
(Integer) |
| NIP | Number of integration points (subsections).
(Integer) |
| CST | Cross section type.
| SCOOR | Beam orientation definition flag.
(Integer) |
| TS1 | Cross section dimension.
(Real) |
| A | Section area. (Real) |
| IYY, IZZ | Area moment of inertia for bending. (Real) |
| IXX | Area moment of inertia for torsion. (Real) |
| VOL | Discrete beam volume. (Real) |
| INERTIA | Discrete mass beam inertia. (Real) |
| CID | Coordinate system identifier for DOF directions of the discrete
beams. (Integer) |
| AREA | Section area of cable elements that use
*MAT_071. (Real) |
| L1, L2 | Dimension of the predefined section. (Real) |
- Converted into /PROP/TYPE3 (BEAM), /PROP/TYPE18 (INT_BEAM), /PROP/TYPE23 (SPR_MAT), or /PROP/TYPE2 (TRUSS).
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
