*AIRBAG_LINEAR_FLUID_ID
LS-DYNA Input Interface KeywordThis model defines a control volume filled with a liquid.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *AIRBAG_LINEAR_FLUID_ID | |||||||
If OPTION = ID, insert the following line
| monvol_ID | Title | ||||||
| surf_IDex | Surf_typ | ||||||
| K | LCINT | LCOUTT | LCOUTP | LCFIT | LCBULK |
Optional card
| P_MAX | P_MAX_ID |
Definition
| monvol_ID | Airbag
identifier. (Integer) |
| Title | Title. (Character) |
| surf_IDex | Airbag external surface
| Surf_typ | Set type.
(Integer) |
| K | Bulk
coefficient. (Real) |
| Density. (Real) |
| LCINT | Mass flow in as function of
time. (Integer) |
| LCOUTT | Mass flow out as function of
time. (Integer) |
| LCOUTP | Mass flow out as function of
time. (Integer) |
| LCFIT | Added pressure as function of
time. (Integer) |
| LCBULK | Bulk coefficient as function of
time. Value of K is ignored in this
case. (Integer) |
| P_MAX | Maximum value of
pressure. (Real) |
| P_MAX_ID | Maximum value of pressure as
function of time. (Integer) |
- This keyword maps to /MONVOL/LFLUID.
