*AIRBAG_PARTICLE
LS-DYNA Input Interface KeywordDefines a Finite Volume Method airbag.
(1) (2) (3) (4) (5) (6) (7) (8)
*AIRBAG_PARTICLE_{OPTION}
If OPTION = ID, insert the following line
monvol_ID Title
surf_IDex Surf_type_ex surf_IDin Surf_type_in
Text Pext Nvent Tswitch
Iair Ngas Ninj
Add Nvent cards for each vent
surf_IDv Surf_type_v Avent FUNCT_ID FUNCP_ID
If Iair > 0, add the card
Pair Tair Mw_air A_air B_air C_air
Add Ngas cards for definition of multi-component gas injection
FM_ID (I) FT_ID (I) Mw (I) A (I) B (I) C (I)
Add Ninj cards for definition of injection holes through shell elements on external surface
EID (I) VID (I)
Definition
OPTION
ID
monvol_ID Airbag identifier.
(Integer)
Title Title.
(Character)
surf_IDex Airbag external surface identifier.
(Integer)
Surf_type_ex External set type.
= 0 (Default)
The surf_IDex is a segment set.
≠ 0
The surf_IDex is a set of parts.
(Integer)
surf_IDin Airbag internal surface identifier.
(Integer)
Surf_type_in Internal set type.
= 0 (Default)
The surf_IDin is a segment set.
≠ 0
The surf_IDin is a set of parts.
(Integer)
Text External temperature.
Default = 295 K (Real)
[ K ]
Pext External pressure.
(Real)
[ Pa ]
Nvent Number of vent holes.
(Integer)
Tswitch Time to switch from finite volume airbag to uniform pressure airbag.
(Real)
[ s ]
Iair Material definition for external air.
= 0 (Default)
Predefined material for air created.
> 0
Air material is created according to the airbag card input.
(Integer)
Ngas Number of injected gas components.
(Integer)
Ninj Number of injection holes.
(Integer)
surf_IDv Airbag vent surface identifier.
(Integer)
Surf_type_v Surface set type.
= 0 (Default)
The surf_IDv is a part ID.
≠ 0
The surf_IDv is a set of parts.
(Integer)
Avent Scaling coefficient for vent area.
Default = 1 (Real)
FUNCT_ID Function identifier for vent area scaling coefficient as function of time.
(Integer)
FUNCP_ID Function identifier for vent area scaling coefficient as function of overpressure.
(Integer)
Pair External pressure (overwrites Pext).
Default = Pext (Real)
[ Pa ]
Tair External temperature (overwrites Text).
Default = Text (Real)
[ K ]
MW_air Molar molecular weight of air.
(Real)
A_air Constant head capacity parameter for air.
(Real)
J mole MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada WcaaqaaiaabQeaaeaacaqGTbGaae4BaiaabYgacaqGLbaaaaGaay5w aiaaw2faaaaa@3C7C@
B_air Linear head capacity parameter for air.
(Real)
[ J mole .K ] MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada WcaaqaaiaabQeaaeaacaqGTbGaae4BaiaabYgacaqGLbGaaeOlaiaa bUeaaaaacaGLBbGaayzxaaaaaa@3DFE@
C_air Quadratic head capacity parameter for air.
(Real)
[ J m o l e ⋅ K 2 ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeaaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada WcaaqaaiaadQeaaeaacaWGTbGaam4BaiaadYgacaWGLbGaeyyXICTa am4samaaCaaaleqabaGaaGOmaaaaaaaakiaawUfacaGLDbaaaaa@4093@
FM_ID (I) Function identifier of gas component mass flow as function of time.
(Integer)
FT_ID (I) Function identifier of gas component temperature as function of time.
(Integer)
MW (I) Molar molecular weight of gas component.
(Real)
A (I) Constant head capacity parameter for gas component.
(Real)
B (I) Linear head capacity parameter for gas component.
(Real)
C (I) Quadratic head capacity parameter for gas component.
(Real)
EID (I) Shell element number defining position of injector.
(Integer)
[ J kg⋅K ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeaaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada WcaaqaaiaabQeaaeaacaqGRbGaae4zaiabgwSixlaabUeaaaaacaGL BbGaayzxaaaaaa@3DB3@
VID (I) Initial direction of gas inflow at nozzle.
= -1 (Default)
Direction of gas inflow is in shell normal direction.
= -2
Direction of gas inflow is reversed relative to shell normal.
(Integer)
  1. This keyword maps to /MONVOL/FVMBAG2, /MAT/GAS, and /PROP/INJECT1.
  2. External surfaces of airbag should form a closed volume.
  3. Airbag external and internal surfaces should not have any intersections.
  4. Injector holes are defined by shell elements on external surfaces.
