*AIRBAG_LOAD_CURVE_ID
LS-DYNA Input Interface KeywordThis model defines a one-chambered airbag with pressure specified as function of time.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *AIRBAG_LOAD_CURVE_ID | |||||||
If OPTION = ID, insert the following line
| monvol_ID | Title | ||||||
| surf_IDex | Surf_typ | ||||||
| STIME | LCID |
Definition
| monvol_ID | Airbag
identifier. (Integer) |
| Title | Title. (Character) |
| surf_IDex | Airbag external surface
| Surf_typ | Set type.
(Integer) |
| STIME | Time shift for pressure
application. (Real) |
| LCID | Load curve ID for pressure versus
time. (Real) |
- This keyword maps to /MONVOL/PRES.
