*AIRBAG_ADIABATIC_GAS_MODEL_ID
LS-DYNA Input Interface KeywordThis model defines a one-chambered airbag filed by adiabatic gas. Uniform pressure method is used.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *AIRBAG_ADIABATIC_GAS_MODEL_ID | |||||||
If OPTION = ID, insert the following line
| monvol_ID | Title | ||||||
| surf_IDex | Surf_typ | ||||||
| Pscale | Gamma | P_int | P_ext |
Definition
| monvol_ID | Airbag
identifier. (Integer) |
| Title | Title. (Character) |
| surf_IDex | Airbag external surface
| Surf_typ | Set type.
(Integer) |
| Pscale | Scaling factor of internal
pressure. (Real) |
| Gamma | Adiabatic
constant. (Real) |
| P_int | Initial internal
pressure. (Real) |
| P_ext | External
pressure. (Real) |
- This keyword maps to /MONVOL/GAS.
