*AIRBAG_SIMPLE_AIRBAG_MODEL
LS-DYNA Input Interface KeywordThis model defines a one-chambered airbag with uniform pressure method, injected gas and vent hole.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*AIRBAG_SIMPLE_AIRBAG_MODEL_{OPTION} |
monvol_ID | Title |
surf_IDex | Surf_typ | ||||||
CV | CP | T | fct_IDM | MU | AREA | Pext | |
fct_IDp | Text | Cpa | Cpb | MW | GASC |
Definition
monvol_ID | Airbag identifier. (Integer) |
Title | Title. (character) |
surf_IDex | Airbag external surface identifier. (Integer) |
Surf_typ | Set type.
(Integer) |
CV | Heat capacity at constant volume. (Real) |
CP | Heat capacity at constant pressure. (Real) |
T | Input gas temperature. (Real) |
fct_IDM | Mass flow rate of injected gas versus time function
MU | Vent hole shape.
Default = 1 (Real) |
Area | Vent hole area.
(Real) |
Pext | External pressure. (Real) |
Ambient density (used if
CV=0). Default = (Real) |
fct_IDp | Vent hole mass flow out function versus absolute pressure
(used if
CV=0). (Integer) |
Text | External temperature. Default = 295 K (Real) |
Cpa | First heat capacity coefficient of injected gas (used if
CV=0). (Real) |
Cpb | First heat capacity coefficient of injected gas (used if
CV=0). (Real) |
MW | Molecular weight of gas(used if
CV=0). (Real > 0) |
GASC | Universal gas constant
(used if
CV=0). (Real) |
- This keyword maps to /MONVOL/AIRBAG1, /MAT/GAS, and /PROP/INJECT1.
- Vent option defined with function fct_IDp can be used only if CV = 0.
