/PROP/INJECT1
Block Format Keyword Describes mass injected for each constituent gas.
| /PROP/INJECT1/inject_ID/unit_ID | |||||||||
| inject_title | |||||||||
| Ngases | Iflow | AscaleT | |||||||
Define mixture data for Ngases gases:
| mat_ID1 | |||||||||
| mat_ID2 | |||||||||
| etc | |||||||||
| mat_IDN | |||||||||
Definition
| inject_ID | Injector
identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit identifier. (Integer, maximum 10 digits) |
| inject_title | Injector
title. (Character, maximum 100 characters) |
| Ngases | Number of
gases. (Integer) |
| Iflow | Mass entity versus time
function input type flag.
(Integer) |
| AscaleT | Abscissa scale factor for
time based functions. Default = 1.0 (Real) |
| mat_IDi | Material identifier that
identifies the gas. (Integer) |
| Mass of injected gas
versus time function identifier
(i=1,2...N). (Integer) |
| Mass function scale factor
(i=1,2...N). Default = 1.0 (Real) |
or | |
| Temperature of injected
gas versus time function identifier
| Temperature function scale
factor (i=1,2...N). Default = 1.0 (Real) |
