/MONVOL/COMMU1
Block Format Keyword Describes multi-chambered airbag with hybrid input of injected gas. This keyword is similar to /MONVOL/COMMU (Obsolete), but has more flexible input.
- Gas materials can be specified in separate /MAT/GAS cards
- Injector can be specified in separate /PROP/INJECT1 for injector
- Scaling of communication area between airbag chambers as function of time or relative pressure is possible
| /MONVOL/COMMU1/monvol_ID/unit_ID | |||||||||
| monvol_title | |||||||||
| surf_IDex | Hconv | ||||||||
| Ascalet | AscaleP | AscaleS | AscaleA | AscaleD | |||||
| mat_ID | Pext | T0 | Iequil | Ittf | |||||
| Njet |
| inject_ID | sens_ID | Ijet | node_ID1 | node_ID2 | node_ID3 |
| fct_IDPt | FscalePt | ||||||||
| Nvent | Nporsurf |
| surf_IDv | Iform | Avent | Bvent | vent_title | |||||
| Tstart | Tstop | IdtPdef | |||||||
| fct_IDt | fct_IDP | fct_IDA | Fscalet | FscaleP | FscaleA | ||||
| fct_IDt' | fct_IDP' | fct_IDA' | Fscalet' | FscaleP' | FscaleA' | ||||
| surf_IDps | Iformps | Iblockage | surface_title | ||||||
| Cps | Areaps | fct_IDcps | fct_IDaps | Fscalecps | Fscaleaps | ||||
| fct_IDv | Fscalev | ||||||||
| Nbag |
| bag_ID | surf_IDc | Acom | Tcom | ||||||
| fct_IDCt | fct_IDCP | FscaleCt | FscaleCP | ||||||
Definition
| monvol_ID | Monitored volume
identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit identifier. (Integer, maximum 10 digits) |
| monvol_title | Monitored volume
title. (Character, maximum 100 characters) |
| surf_IDex | External surface
identifier. (Integer) |
| Hconv | Heat transfer coefficient.
23 (Real) |
| Ascalet | Abscissa scale factor for
time based functions. Default = 1.0 (Real) |
| AscaleP | Abscissa scale factor for
pressure based functions. Default = 1.0 (Real) |
| AscaleS | Abscissa scale factor for
area based functions. Default = 1.0 (Real) |
| AscaleA | Abscissa scale factor for
angle based functions. Default = 1.0 (Real) |
| AscaleD | Abscissa scale factor for
distance based functions. Default = 1.0 (Real) |
| mat_ID | Material identifier for
initial gas (/MAT/GAS). (Integer) |
| Volumetric
viscosity. Default = 0.01 (Real) |
| Pext | External
pressure. (Real) |
| T0 | Initial
temperature. Default = 295K (Real) |
| Iequil | Initial thermodynamic
equilibrium flag.
(Integer) |
| Ittf | Time shift flag. Only
active when at least one injection sensor is specified.
Determines time shift for venting, porosity and communication
options when injection starts at a Time to Fire specified in a sensor.
(Integer) |
| Njet | Number of
injectors. (Integer) |
| inject_ID | Injector property
| sens_ID | Sensor
| Ijet | Jetting flag.
(Integer) |
| node_ID1, node_ID2, node_ID3 | Node identifiers N1, N2, and N3 for jet shape definition. (Integer) |
| fct_IDPt | Identifier of the function
number defining
. (Integer) |
number defining
. (Integer) |
number defining
. (Integer) |
| FscalePt | Scale factor for
fct_IDPt. Default = 1.0 (Real) |
| Scale factor for
| Scale factor for
| Nvent | Number of vent
holes. (Integer) |
| Nporsurf | Number of porous
surfaces. (Integer) |
| surf_IDv | Vent holes area surface
| Iform | Formulation flag.
(Integer) |
| Avent | If
surf_IDv≠ 0:
scale factor on vent hole area. Default = 1.0 (Real) |
| If
surf_IDv = 0:
vent hole area Default = 0.0 (Real) |
| Bvent | If
surf_IDv ≠ 0:
scale factor on impacted vent hole area. Default = 1.0 (Real) |
| If
surf_IDv = 0:
Bvent is reset
to 0 for vent hole area. Default = 0.0 (Real) |
| vent_title | Vent hole
title. (Character, maximum 20 characters) |
| Tstart | Start time for
venting. Default = 0 (Real) |
| Tstop | Stop time for
venting. Default = 1030 (Real) |
| Pressure difference to
open vent hole membrane.
| Minimum duration pressure
exceeds Pdef to
open vent hole. Default = 0 (Real) |
| IdtPdef | Time delay flag when
is reached:
(Integer) |
| fct_IDt | Porosity versus time
function identifier. (Integer) |
| fct_IDP | Porosity versus pressure
| fct_IDA | Porosity versus area
| Fscalet | Scale factor for
fct_IDt. Default = 1.0 (Real) |
| FscaleP | Scale factor for
fct_IDP. Default = 1.0 (Real) |
| FscaleA | Scale factor for
fct_IDA. Default = 1.0 (Real) |
| fct_IDt' | Porosity versus time
function identifier during contact. (Integer) |
| fct_IDP' | Porosity versus pressure
| fct_IDA' | Porosity versus impacted
surface function identifier during contact. (Integer) |
| Fscalet' | Scale factor for
fct_IDt'. Default = 1.0 (Real) |
| FscaleP' | Scale factor for
fct_IDP'. Default = 1.0 (Real) |
| FscaleA' | Scale factor for
fct_IDA'. Default = 1.0 (Real) |
| surf_IDps | Porous surface identifier
(ignored if Iformps
= 0). (Integer) |
| Iformps | Porosity formulation.
(Integer) |
| Iblockage | Block leakage flag, if
contact (Iformps > 0).
(Integer) |
| surface_title | Porous surface
| Cps | Scale factor on leakage
area (Iformps
=0). (Real) |
| Areaps | Leakage area
(Iformps=0). (Real) |
| fct_IDcps | Function identifier
defining
Cps(t),
ignored if Cps is
not equal to zero. (Integer) |
| fct_IDaps | Function identifier
defining
Areaps(P-Pext), ignored if
Areaps is not
| Fscalecps | Scale factor for
fct_IDcps. Default = 1 (Real) |
| Fscaleaps | Scale factor for
fct_IDaps Default = 1 (Real) |
| fct_IDv | Outflow velocity function
identifier, Chemkin model. (Integer) |
| Fscalev | Scale factor on
fct_IDv. Default = 1.0 (Real) |
| Nbag | Number of communicating
airbags. (Integer) |
| bag_ID | Airbag identifier. 20 (Integer) |
| surf_IDC | Communicating surface
open communication surface membrane. (Real) |
| Acom | Communicating surface, if surf_IDC = 0. | |
| Scale factor on surface,
if surf_IDC ≠
0. Default = 1.0 (Real) 23 |
| Tcom | Start time for
communication. (Real) |
difference exceeds
to open communication surface
membrane. (Real) |
| fct_IDCt | Communicating surface
versus time function identifier. (Integer) |
| fct_IDCP | Communicating surface
versus relative pressure function
| FscaleCt | Scale factor for
fct_IDCt. Default = 1.0 (Real) |
| FscaleCP | Scale factor for
fct_IDCP. Default = 1.0 (Real) |
- The airbag external surface should be built only from 4- and 3- noded shell elements. The airbag external surface cannot be defined with /SURF/SEG, nor with /SURF/SURF, if a sub-surface is defined in /SURF/SEG.
- The volume must be closed and the normals must be oriented outwards.
- Abscissa scale factors are used
to transform abscissa units in airbag functions, for example:Where,
- Time
- Function of fct_IDt
Where,- Pressure
- Function of fct_IDP
- Pressure and temperature of external air and the initial pressure and temperature of air inside of airbag is set to Pext and T0.
- The characteristics of the gas initially filling the airbag (temperature and pressure) must be defined (no default) and must be equal for each communicating airbag.
- Initial thermodynamic equilibrium
is written at time zero (Iequil =0) or at beginning of jetting
(Iequil =1), based on the following
equation with respect to the volume at time zero, or the volume at beginning of
jetting:
Where, is the mass of gas initially filling the airbag, is the molar mass of the gas initially filling the airbag, and is the gas constant depending on the units system given the in /BEGIN card. For example in SI system:
- If jetting is used, an additional
pressure is applied to each element of the
airbag:
Function is automatically shifted by time given in sensor, which activates injection.
- With m being the
normalized vector between the projection of the center of the element upon
segment (N1 and N3) and the center of the element;
the angle between vectors
MN2 and m (in degrees),
is the distance between the center of the element and
its projection upon segment (N1 and N3).The projection of a point upon segment (N1 and N3) is defined as the projection of the point in direction MN2 upon the line (N1 and N3) if it lies inside the segment (N1 and N3). If this is not the case, the projection of the point upon segment (N1 and N3) is defined as the closest node N1 or N3.
Figure 1. Dihedral Shape of the Jet
with M between N1 and N3
- If node_ID3 = 0, node_ID3 is set to node_ID1 and the dihedral shape is reduced to a conical shape.
- If
fct_IDv = 0:
isenthalpic outflow is assumed, otherwise Chemkin model is used and outflow
velocity is:Where, is the function of fct_IDv.
- Isenthalpic model
Venting or the expulsion of gas from the volume is assumed to be isenthalpic.
The flow is also assumed to be unshocked, coming from a large reservoir and through a small orifice with effective surface area, A.
Conservation of enthalpy leads to velocity, u at the vent hole. The Bernouilli equation is then written as:
(monitored volume) (vent hole)
Applying the adiabatic conditions:
Where,- Pressure of gas into the airbag.
- Density of gas into the airbag.
Therefore, the exit velocity is given by:
For supersonic flows the outlet velocity is determined as described in Supersonic Outlet Flow in the Theory Manual.
The mass out flow rate is given by:
The energy flow rate is given by:
Where,- Airbag volume.
- Internal energy of gas into the airbag.
- Chemkin modelWhere,
- Density of the gas within the airbag.
- Function of fct_IDv.
- Isenthalpic model
- Vent holes area is computed as
follows:
With impacted surface:
and non-impacted surface:Figure 2.
Where for each element e of the airbag materials means the number of impacted nodes among the nodes defining the element and is the area of element e.
And,
A0 is the initial area of surface surf_IDv
, and fA are functions of fct_IDt, fct_IDP and fct_IDA
ft', fP' and fA' are functions of fct_IDt', fct_IDP' and fct_IDA'
- Functions fct_IDt' and fct_IDP' are assumed to be equal to 1, if they are not specified (null identifier).
- Function
fct_IDA' is assumed as:
if it is not specified.
- To account for contact blockage of vent holes and porous surface area, flag IBAG must be set to 1 in the correspondent interfaces (Line 3 of interface TYPE7 or TYPE23). If not, the nodes impacted into the interface are not considered as impacted nodes in the previous formula for Aimpacted and Anon_impacted.
- Vent holes and interchamber components should be included into the airbag (chamber) external surface.
- When there is no sensor which activates gas injection, the vent holes and porosity becomes active, if time T becomes greater than the Tstart or if the pressure P exceeds Pdef value longer than the time given in .
- When at least one of the
injectors is activated by the sensor, then activation of venting, porosity and
communication options is controlled by
Ittf.
Tinj is the time of the first injector to be activated by the sensor.
Iinj = 0:Venting, Porosity Communication Activation When longer than the time , or When longer than the time , or Deactivation Tstop N/A Time dependent functions No shift No shift Ittf = 3:Venting, Porosity Communication Activation When and longer than the time , or When and longer than the time , or Deactivation N/A Time dependent functions Shifted by Shifted by All other related curves are active when the corresponding venting, porosity or communication option is active.
The variety of Ittf values comes from historical reasons. Values Ittf=1 and 2 are obsolete and should not be used. Usual values are Ittf=0 (no shift) or Ittf=3 (all relative options are shifted by Tinj).
- Leakage by porosity
formulations; the mass flow rate flowing out is computed as:
- Iformps = 0
(Isentropic - Wang
Nefske)
with
and or
Note that the effective venting area Aeff does not vary with different airbag fabric materials.
- Iformps > 0, the effective venting area Aeff is computed according to the input in the /LEAK/MAT input for fabric materials of TYPE19 or TYPE58.
- Iformps = 1 (Isentropic - Wang Nefske)
- Iformps = 2
Where, v is the outflow gas velocity (Chemkin)
- Iformps = 3 (Graefe)
- Iformps = 0
(Isentropic - Wang
Nefske)
- If leakage blockage is activated,
Iblockage=1, the effective venting area is modified
as:
Anon_impacted is non-impacted surface. 11
The blockage will be active only if flag IBAG is set to 1 in the concerned contact interfaces (line 3 of interface TYPE7 and TYPE23).
- It is not allowed to combine /MONVOL/COMMU and /MONVOL/COMMU1 cards in one multi-chambered airbag. However, in the same model it is possible to use different multi-chambered airbags (based on /MONVOL/COMMU or /MONVOL/COMMU1) for each airbag.
- When there is no sensor which activates gas injection, the communication surface is open if T > Tcom or if the pressure exceeds during more than . 17
- Communication surface,
Scom is computed as:
- if surf_ID =0,
- if surf_ID > 0 and Area is the surface of surf_ID,
Where, is the pressure difference between the chambers and and are functions of fct_IDCt and fct_IDCP
- if surf_ID =0,
- The lost heat flow is given
by:
