/PROP/INJECT2
Block Format Keyword Describes molar fraction injected for each constituent gas and total mass injected.
| /PROP/INJECT2/inject_ID/unit_ID | |||||||||
| inject_title | |||||||||
| Ngases | Iflow | ||||||||
| fct_IDM | fct_IDT | FscaleM | FscaleT | AscaleT | |||||
Define mixture data for Ngases gases: define
molar fraction for constant gas mixture or function for gas mixture variable with
time
| mat_ID1 | Molar_Fraction1 | ||||||||
| mat_ID2 | Molar_Fraction2 | ||||||||
| etc | |||||||||
| mat_IDN | Molar_FractionN | ||||||||
Definition
| inject_ID | Injector
identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit identifier. (Integer, maximum 10 digits) |
| inject_title | Injector
title. (Character, maximum 100 characters) |
| Ngases | Number of
gases. (Integer, 1 ≤ Ngases ≥ 100) |
| Iflow | Mass versus time function
input type flag.
(Integer) |
| fct_IDM | Mass of injected gas
versus time function identifier. (Integer) |
| fct_IDT | Temperature of injected
gas versus time function identifier. (Integer) |
| FscaleM | Mass function scale
factor. Default = 1.0 (Real) |
or |
| FscaleT | Temperature function scale
| AscaleT | Abscissa scale factor for
time based functions. 1 Default = 1.0 (Real) |
| mat_IDi | Material identifier that
identifies the gas
(i=1,2...N). (Integer) |
| Molar_Fractioni | Molar fraction of injected
gas (i=1,2...N). (Real) |
- The sum of Molar_Fraction must be 1.0 at any given time.
- The are function identifiers used to define variable molar fraction with time. The function must be defined with the same time abscissa. If > 0, Molar_Fraction is not used.
