*AIRBAG_SHELL_REFERENCE_GEOMETRY
LS-DYNA Input Interface KeywordDefine the reference state for elements belonging to a part using given element and node identifiers with possible scaling for the nodes with defined scale center and scale factor.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*AIRBAG_SHELL_REFERENCE_GEOMETRY_{OPTION} |
FscaleX | FscaleY | FscaleZ | node_IDc |
shell_ID | part_ID | node_ID1 | node_ID2 | node_ID3 | node_ID4 |
Definition
FscaleX | X scale factor. Default = 1.0 (Real) |
FscaleY | Y scale factor. Default = 1.0 (Real) |
FscaleZ | Z scale factor. Default = 1.0 (Real) |
node_IDc | Center node
identifier. (Integer) |
shell_ID | Shell
part_ID | (Optional) Part
node_ID1 | Node 1
node_ID2 | Node 2
node_ID3 | Node 3
node_ID4 | Node 4
- This keyword maps to /EREF and /TRANSFORM/SCA.
