/TRANSFORM/SCA
Block Format Keyword Defines a scale for a node group with defined scale center and scale factor.
/TRANSFORM/SCA/transform_ID/unit_ID
transform_title
grnd_ID FscaleX FscaleY FscaleZ node_IDc
Definition
transform_ID Transformation identifier.
(Integer, maximum 10 digits)
unit_ID Unit identifier.
transform_title Transformation title.
grnd_ID Node group identifier. 4
(Integer)
FscaleX X scale factor.
Default = 0.0 (Real)
FscaleY Y scale factor.
FscaleZ Z scale factor.
node_IDc Center node identifier.
(Integer)
  1. The node node_IDc is the scale center.
  2. If the node node_IDc is not defined, the origin (0,0,0) will be used as scale center.
  3. The scaling is done in the global frame.
  4. Transforms applied to node groups only transform the nodal coordinates. Material directions for orthotropic materials and boundary conditions such as initial velocity, imposed movement are not transformed.
