*MAT_S06 (SPRING_GENERAL_NONLINEAR)
LS-DYNA Input Interface KeywordDefines a nonlinear spring material with loading and unloading options.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*MAT_S06 or *MAT_SPRING_GENERAL_NONLINEAR | |||||||
mat_ID | LCL | LCU |
Definition
mat_ID | Material identifier. (Integer) |
LCL | Loading curve identifier for force versus displacement or
moment versus rotation. (Integer) |
or |
LCU | Unloading curve identifier for force versus displacement or
or |
- This keyword maps to /MAT/LAW108 (SPR_GENE).
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
