*MAT_S08 (SPRING_INELASTIC)
LS-DYNA Input Interface KeywordDefines a nonlinear spring material with stiffness available only in tension or in compression.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*MAT_S08 or *MAT_SPRING_INELASTIC | |||||||
mat_ID | LCFD | CTF |
Definition
mat_ID | Material identifier. (Integer) |
LCFD | Loading curve identifier: force versus displacement or moment
versus rotation angle. The curve should start with (0, 0) and be
defined in first quadrant only. (Integer) |
CTF |
(Integer) |
- This keyword maps to /MAT/LAW108 (SPR_GENE).
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
