*MAT_S15 (SPRING_MUSCLE)
LS-DYNA Input Interface KeywordDefines a muscle model for discrete elements.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_S15 or *MAT_SPRING_MUSCLE | |||||||
| mat_ID | L0 | Vmax | At | Force | FL | FV | |
| FP | LMAX | KSH | |||||
Definition
| mat_ID | Material
identifier. (Integer) |
| L0 | Initial muscle
length. (Real) |
| Vmax | Maximum shortening
velocity. (Real) |
| At | Activation factor versus time.
(Real) |
| Force | Peak isometric
force. (Real) |
| FL | Active tension as function of length.
(Real) |
| FV | Active stress factor as function of velocity.
(Real) |
| FP | Normalized force as function of
length for parallel elastic element.
(Integer) |
| LMAX | Relative length at Force. Used only
when FP =
0. (Real) |
| KSH | Constant for passive element. Used
only when FP =
0. (Real) |
- This keyword maps to /PROP/TYPE46 (SPR_MUSCLE).
- This keyword is used only with discrete elements.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
