*MAT_002 (ORTHOTROPIC_ELASTIC)
LS-DYNA Input Interface KeywordThis model expresses a simple orthotropic elastic material.
(1) (2) (3) (4) (5) (6) (7) (8)
*MAT_002 or *MAT_ORTHOTROPIC_ELASTIC
mat_ID ρ i E11 E22 E33 υ12
G12 G23 G31 AOPT
A1 A2 A3
D1 D2 D3
Definition
mat_ID Material identifier.
(Integer)
ρ i Initial density.
(Real)
[ kg m 3 ]
E11 Young's modulus in direction 1.
(Real)
[ Pa ]
E22 Young's modulus in direction 2.
(Real)
[ Pa ]
E33 Young's modulus in direction 3.
(Real)
[ Pa ]
υ12 Poisson's ratio.
(Real)
G12 Shear modulus in direction 12.
(Real)
[ Pa ]
G23 Shear modulus in direction 23.
(Real)
[ Pa ]
G31 Shear modulus in direction 31.
(Real)
[ Pa ]
AOPT Orthotropy axis option.
= 2
Orthotropy axis determined by A1, A2, A3, D1, D2, D3.
< 0
AOPT is number of *DEFINE_COORDINATE_* to define orthotropic system.
(Integer)
A1, A2, A3 First orthotropy direction vector for AOPT = 2.
(Real)
D1, D2, D3 With A1, A2, A3 determines 12 planes of orthotropy for AOPT = 2.
(Real)
  1. This keyword maps to /MAT/LAW93 (ORTH_HILL) or (CONVERSE).
  2. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
