*MAT_181 (SIMPLIFIED_RUBBER/FOAM)
LS-DYNA Input Interface KeywordDefines a rubber and foam material with uniaxial tensile/compression test results as input curve. This material can be used with solid elements only.
(1) (2) (3) (4) (5) (6) (7) (8)
*MAT_181 or *MAT_SIMPLIFIED_RUBBER/FOAM
mat_ID ρ i K Mu G
Length Width Thick Table_ID Tension
Optional card 1: unloading behavior
Fct_unl Hys Shape
Definition
mat_ID Material identifier.
(Integer)
ρ i Poisson's ratio.
(Real)
[ kg m 3 ]
K Bulk modulus.
(Real)
[ Pa ]
Mu Numerical Navier Stokes viscosity.
Default = 0.1 (Real)
G Shear modulus.
(Real)
[ Pa ]
Length Specimen gauge length.
(Real)
[ m ]
Width Specimen gauge width.
(Real)
[ m ]
Thick Specimen gauge thickness.
(Real)
[ m ]
Table_ID Curve or table identifier defining the force versus gauge length and for the different strain rate value defined in the table.
(Integer)
Tension Unloading rate effects option flag.
= -1
Unloading in tension follows the quasi static unloading curve; Unloading in compression follow the loading strain rate dependent curves.
= 0 (Default)
Unloading follows the quasi-static unloading curve.
= 1
Unloading follows the loading strain rate dependent curves and the unloading curve is not used.
(Integer)
Fct_unl Unloading curve identifier.
(Integer)
Hys Hysteresis unloading factor. Ignore if, unloading function is used.
0.0 ≤ Hys ≤ 1.0
Default = 0 (Real)
Shape Shape factor. Ignored if, unloading function is used.
Default = 1.0 (Real)
  1. This keyword maps to /MAT/LAW70 (FOAM_TAB) for foam, and /MAT/LAW88 for the hyperelastic materials.
  2. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
