*MAT_138 (COHESIVE_MIXED_MODE)
LS-DYNA Input Interface KeywordThis model expresses a constitutive relation of ductile adhesive materials in 2 modes for normal and tangential directions.
(1) (2) (3) (4) (5) (6) (7) (8)
*MAT_138 or *MAT_COHESIVE_MIXED_MODE
mat_ID ρ i ROFLG Idel EN ET GIC GIIC
XMU TN TT UDN UTD Gamma
Definition
mat_ID Material identifier.
(Integer)
ρ i Initial density.
(Real)
[ kg m 3 ]
ROFLG Mass calculation flag.
= 0 (Default)
Element mass is calculated using density and volume.
= 1
Element mass is calculated using density and mean area.
(Integer)
Idel Failure flag indicating the number of integration points to delete the element (between 1 and 4).
Default = 1 (Integer)
EN Stiffness normal to the plane of the cohesive element.
(Real)
[ Pa ]
ET Stiffness into the plane of the cohesive element.
(Real)
[ Pa ]
GIC Energy release rate for mode I.
(Real)
[ Pa.m ] MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaaca WGqbGaamyyaiaac6cacaWGTbaacaGLBbGaayzxaaaaaa@3B48@
GIIC Energy release rate for mode II.
(Real)
[ P a . m ] MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaaca WGqbGaamyyaiaac6cacaWGTbaacaGLBbGaayzxaaaaaa@3B48@
XMU Exponent of the mixed mode criteria.
(Real)
TN Peak traction in normal direction.
< 0
Function ID (abs(T)) of peak traction value as a function of the square root of the area of ​​the median plane of the connecting element.
= 0
Peak traction computed from UDN and GIC.
> 0
Peak traction value.
(Real)
[ Pa ]
TT Peak traction in tangential direction.
< 0
Function ID (abs(S)) of peak traction value as a function of the square root of the area of ​​the median plane of the connecting element.
= 0
Peak traction computed from UTN and GIIC.
> 0
(Real)
[ Pa ]
UDN Ultimate displacement in the normal direction.
Used only if TN=0, then T N = 2 * G I C U D N MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamivaiaad6 eacqGH9aqpdaWcaaqaaiaaikdacaGGQaGaam4raiaadMeacaWGdbaa baGaamyvaiaadseacaWGobaaaaaa@3EFB@
(Real)
[ m ]
UTD Ultimate displacement in the tangential direction.
Used only if TT=0, then T T = 2 * G I I C U T N MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamivaiaads facqGH9aqpdaWcaaqaaiaaikdacaGGQaGaam4raiaadMeacaWGjbGa am4qaaqaaiaadwfacaWGubGaamOtaaaaaaa@3FDF@
(Real)
[ m ]
Gamma Benzeggagh-Kenane exponent for the mixed mode.
(Real)
  1. This keyword maps to /MAT/LAW117.
  2. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
