*MAT_S02 (DAMPER_VISCOUS)
LS-DYNA Input Interface KeywordDefines a linear damper spring material.
(1) (2) (3) (4) (5) (6) (7) (8)
*MAT_S02 or *MAT_DAMPER_VISCOUS
mat_ID D
Definition
mat_ID Material identifier.
(Integer)
D Linear or rotational damping.
(Real)
[ Ns m ] or [ Nms rad ]
  1. This keyword maps to /MAT/LAW108 (SPR_GENE).
  2. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
