*MAT_032 (LAMINATED_GLASS)
LS-DYNA Input Interface KeywordThis keyword defines a layered glass with polymeric layers material models.
(1) (2) (3) (4) (5) (6) (7) (8)
*MAT_032 or *MAT_LAMINATED_GLASS
mat_ID ρ i E_g Νu_g SIG_g ET_g EPSP_g E_p
Νu_p SIG_p ET_p
Add up to 4 cards (32 integration points).
F1 F2 F3 F4 F5 F6 F7 F8
etc
etc
etc etc       F30 F31 F32
Definition
mat_ID Material identifier.
(Integer)
ρ i Initial density.
(Real)
[ kg m 3 ]
E_g Glass Young’s modulus.
(Real)
[ Pa ]
Nu_g Glass Poisson’s ratio.
(Real)
SIG_g Glass yield stress.
(Real)
[ Pa ]
ET_g Glass plastic hardening modulus.
(Real)
[ Pa ]
EPSP_g Glass plastic strain failure.
(Real)
E_p Polymer Young’s modulus.
(Real)
[ Pa ]
Νu_p Polymer Poisson’s ratio.
(Real)
SIG_p Polymer yield stress.
(Real)
[ Pa ]
ET_p Polymer plastic hardening modulus.
(Real)
[ Pa ]
F1 to F32 Integration point material.
= 0
Glass material.
= 1
Polymer material.
(Real)
  1. This keyword maps to /MAT/LAW27 (PLAS_BRIT) and /PROP/TYPE11 (SH_SANDW).
  2. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
