*MAT_154 (DESHPANDE_FLECK_FOAM)
LS-DYNA Input Interface KeywordDefines a material for modeling aluminum foam.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_154 or *MAT_DESHPANDE_FLECK_FOAM | |||||||
| mat_ID | RHO_I | E | NU | ALPHA | GAMMA | ||
| EPSI_D | ALPHA2 | BETA | SIGP | EPS_F | SIGMA_F | ||
Definition
| mat_ID | Material
identifier. (Integer) |
| RHO_I | Initial
density. (Real) |
| E | Elastic
modulus. (Real) |
| NU | Poisson’s
ratio. (Real) |
| ALPHA | Yield surface shape
parameter. (Real) |
| GAMMA | Linear hardening
modulus. (Real) |
| EPSI_D | Densification
strain. (Real) |
| ALPHA2 | Nonlinear hardening
modulus. (Integer) |
| BETA | Nonlinear hardening
parameter. (Real) |
| SIGP | Initial flow
stress. (Real) |
| EPS_F | Tensile volumetric plastic strain
at failure. (Real) |
| SIGMA_F | Maximum principal stress at
failure. (Real) |
- This keyword maps to /MAT/LAW115 (DESHFLECK).
- This keyword is used only with solid elements.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
