*MAT_073 (LOW_DENSITY_VISCOUS_FOAM)
LS-DYNA Input Interface KeywordDefines a visco-elastic low density foam tabulated material for solid elements.
(1) (2) (3) (4) (5) (6) (7) (8)
*MAT_073 or *MAT_LOW_DENSITY_VISCOUS_FOAM
mat_ID ρ i E Fct_ID Hys DAMP
Shape
Optional isotropic visco-elastic Maxwell parameters (up to 6 lines)
G_i Beta_i
Definition
mat_ID Material identifier.
(Integer)
ρ i Initial density.
(Real)
[ kg m 3 ]
E Shear modulus.
(Real)
[ Pa ]
Fct_ID Load function identifier.
(Integer)
Hys Hysteresis unloading factor.
Default = 1.0 (Real)
DAMP Viscous coefficient to model damping effects.
Default = 0.05 (Real)
Shape Shape factor.
G_i Shear relaxation modulus for ith term (up to 6 terms).
(Real)
[ Pa ]
BETA_i Decay bulk constant for ith term (up to 6 terms).
(Real
[ 1 s ]
  1. This keyword maps to /MAT/LAW90 and /VISC/PRONY.
  2. Material behavior in tension and in compression is determined by a curve defined as:
    • Positive abscissa and ordinate for the compression
    • Negative abscissa and ordinate for traction (tension)
  3. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
