*MAT_163 (MODIFIED_CRUSHABLE_FOAM)
LS-DYNA Input Interface KeywordThis model expresses a strain rate dependent crushable foam material. This law is applicable only for solid elements and is typically used to model low density, closed cell polyurethane foams.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_163 or *MAT_MODIFIED_CRUSHABLE_FOAM | |||||||
| mat_ID | E | n | Tab_ID | TSC | DAMP | NCYCLE | |
| SRC_LIMIT | NRS | ||||||
Definition
| mat_ID | Material
identifier. (Integer) |
| Initial
density. (Real) |
| E | Young’s
modulus. (Real) |
| n | Poisson’s
ratio. (Real) |
| Tab_ID | Yield stress table identifier
versus volumetric strain and volumetric strain
rate. (Integer) |
| TSC | Tensile stress cutoff. Default = 1020 (Real) |
| DAMP | Damping coefficient (recommended
between 0.05 and 0.5). (Real) |
| NCYCLE | Number of cycles for volumetric
strain rate filtering. Default = 12 (Integer) |
| SRC_LIMIT | Strain rate change limit. Default = 1020 (Real) |
| NRS | Strain rate dependency type flag.
(Integer) |
- This keyword maps to /MAT/LAW163 (CRUSHABLE_FOAM).
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
