*MAT_122 (HILL_3R)
LS-DYNA Input Interface KeywordDefines an orthotropic elastoplastic material using linear or tabulated stress versus plastic strain input.
This material is only compatible with shell elements.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_122 or *MAT_HILL_3R | |||||||
| mat_ID | E | HARD | H1 | H2 | |||
| R00 | R45 | R90 | LCSS | ||||
| AOPT | |||||||
| A1 | A2 | A3 | |||||
| V1 | V2 | V3 | BETA | ||||
Definition
| mat_ID | Material
Identifier. (Integer) |
| Initial
density. (Real) |
| E | Young’s
modulus. (Real) |
| Poisson’s ratio. Default = 0 (Real) |
| HARD | Hardening flag:
(Integer) |
| H1 | If
HARD=1: Tangent
hardening modulus. (Real) |
| H2 | If
HARD=1: Yield
stress (Real) |
| R00, R45, R90 | Lankford
coefficients. (Real) |
| LCSS | Stress versus plastic strain curve
identifier. (Integer) |
| AOPT | Material axis flag.
(Real) |
| A1, A2, A3 | Vector defining first orthotropy
direction for
AOPT=2. (Real) |
| V1, V2, V3 | A vector which in combination with
element normal defines the first orthotropy direction for
AOPT=3. (Real) |
| BETA | Material angle for
AOPT = 0 or
3. (Real) |
- This keyword maps to /MAT/LAW43 (HILL_TAB) and orthotropic shell property card.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
