*MAT_252 (TOUGHENED_ADHESIVE_POLYMER)
LS-DYNA Input Interface KeywordThis is a non-associated elasto-plastic model for polymer adhesives.
The constitutive model is based on I1-J2 criterion that can be reduced to von Mises or Drucker-Prager type in compression.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_252 or *MAT_TOUGHENED_ADHESIVE_POLYMER | |||||||
| mat_ID | E | NU | Iform | Itrx | Idam | ||
| Table_ID | Tau_0 | Q | Beta | H | C | Epsd_ref | Epsd_max |
| AF1 | AF2 | AH1 | AH2 | AS | Exp_n | ||
| D1C | D2C | D1F | D2F | DTRX | DJC | ||
Definition
| mat_ID | Material
identifier. (Integer) |
| Initial
density. (Real) |
| E | Elastic
modulus. (Real) |
| NU | Poisson’s
ratio. (Real) |
| Iform | Yield criterion formulation.
(Integer) |
| Itrx | Damage dependency on triaxiality in
compression flag.
(Integer) |
| Idam | Strain rate definition in damage
model flag.
(Integer) |
| Table_ID | Table identifier to define yield
stress as a function of plastic strain, strain rate and
temperature. (Integer) |
| Tau_0 | Initial yield
stress. (Real) |
| Q | Voce hardening
modulus. (Real) |
| Beta | Voce nonlinear hardening
modulus. (Real) |
| H | Linear hardening
exponent. (Real) |
| C | Johnson-Cook strain rate
coefficient for hardening . (Real) |
| Epsd_ref | Quasi-static threshold strain rate
in Johnson-Cook term. (Real) |
| Epsd_max | Maximum dynamic threshold strain
rate in Johnson-Cook term. (Real) |
| AF1, AF2 | Yield function
parameter. (Real) |
| AH1, AH2 | Yield function distortional
hardening parameter. (Real) |
| AS | Plastic flow function parameter for
hydrostatic term. (Real) |
| Exp_n | Exponential coefficient for damage
strain rate dependency. (Real) |
| D1C, D2C | Johnson-Cook parameter for damage
initiation. (Real) |
| D1F, D2F | Johnson-Cook parameter for failure
strain. (Real) |
| DTRX | Johnson-Cook damage parameter for
triaxiality term. (Real) |
| DJC | Johnson-Cook strain rate parameter
for damage. (Real) |
- This keyword maps to /MAT/LAW120 (TAPO).
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
