*MAT_077_O (OGDEN_RUBBER)
LS-DYNA Input Interface KeywordDefines an isotropic, hyperelastic, viscous, and incompressible material specified using the Ogden material models.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_077_O or *MAT_OGDEN_RUBBER | |||||||
| mat_ID | ν | N_pair | |||||
| μ1 | μ2 | μ3 | μ4 | μ5 | μ6 | μ7 | μ8 |
| α1 | α2 | α3 | α4 | α5 | α6 | α7 | α8 |
| SGL | SW | ST | Fct_ID | DATA |
| Gi | i |
Definition
| mat_ID | Material
identifier. (Integer) |
| Initial
density. (Real) |
| v | Poisson’s ratio. Default = 0.495 (Real) |
| N_pair | The number of material parameter
(μi and αi) pairs
calculated in the representation of the strain energy density
function (W). The material parameters are calculated from the
given stress-strain curve
(fct_ID). (N_pair ≤ 5) Default = 2 (Integer) |
| μ1 - μ8 | Parameter of the shear hyperelastic
modulus. (Real) |
| α1 - α8 | Exponent of the shear hyperelastic
modulus. (Real) |
| SGL | Specimen gauge length. | |
| SW | Specimen width length. | |
| ST | Specimen thickness. | |
| Fct_ID | Function identifier for the force
versus change in gauge length. Compression is defined in the 3rd
quadrant (negative) and Tensile is defined in the 1st quadrant
(positive). (Integer) |
| DATA | Experimental data type.
(Integer) |
| Gi | Shear modulus for relaxation. | |
| i | Decay constant for relaxation. |
- This keyword maps to /MAT/LAW42 (OGDEN) (if N_pair = 0) or /MAT/LAW69 (N_pair > 0).
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
