*MAT_058 (LAMINATED_COMPOSITE_FABRIC)
LS-DYNA Input Interface KeywordDefines an orthotropic shell composite material for unidirectional layers, complete laminates, and woven fabrics material.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_058_{OPTION} or *MAT_LAMINATED_COMPOSITE_FABRIC_{OPTION} | |||||||
| mat_ID | E1 | E2 | E3 | 12 | Tau1 | Gamma1 | |
| G12 | G23 | G31 | SLIMT1 | SLIMC1 | SLIMT2 | SLIMC2 | SLIMS |
| AOPT | ERODS | ||||||
| XP | YP | ZP | A1 | A2 | A3 | ||
| V1 | V2 | V3 | D1 | D2 | D3 | BETA | |
| E11C | E11T | E22C | E22T | GMS | |||
| XC | XT | YC | YT | SC | |||
Definition
| OPTION | Element selection.
(Character) |
| mat_ID | Material
identifier. (Integer) |
| Initial
density. (Real) |
| E1 | Young’s modulus in material
directions 1. (Real) |
| E2 | Young’s modulus in material
directions 2. (Real) |
| E3 | Young’s modulus in material
directions 3. (Real) |
| 12 | Poisson’s ratio between directions
1 and 2. (Real) |
| Tau1 | Shear stress limit in direction 12
for nonlinear behavior. (Real) |
| Gamma1 | Shear strain limit in direction 12
| G12 | Shear modulus in direction
12. (Real) |
| G23 | Shear modulus in direction
23. (Real) |
| G31 | Shear modulus in direction
31. (Real) |
| SLIMT1 | Factor to determine the minimum
tensile stress limit after stress maximum in direction
1. (Real) |
| SLIMC1 | Factor to determine the minimum
compression stress limit after stress maximum in direction
1. (Real) |
| SLIMT2 | Factor to determine the minimum
2. (Real) |
| SLIMC2 | Factor to determine the minimum
2. (Real) |
| SLIMS | Factor to determine the minimum
shear stress limit after stress maximum. (Real) |
| AOPT | Material axis flag.
(Integer) |
| ERODS | Maximum tensile strain for element
deletion in direction 1 and 2. (Real) |
| XP, YP, ZP | Coordinates of reference point for
AOPT = 1 and
4. (Real) |
| A1, A2, A3 | Vector defining first orthotropy
direction for AOPT =
2. (Real) |
| V1, V2, V3 | A vector which in combination with
element normal defines the first orthotropy direction for
AOPT = 3 and
4. (Real) |
| D1, D2, D3 | Components of vector for
AOPT =
2. (Real) |
| BETA | Material angle for
AOPT = 0,
3. (Real) |
| E11C | Initial softening strain in
compression in the material direction 1. (Real) |
| E11T | Initial softening strain in tension
| E22C | Initial softening strain in
compression in the material direction 2. (Real) |
| E22T | Initial softening strain in tension
| GMS | Initial softening shear
strain. (Real) |
| XT | Yield stress in tension in
| XC | Yield stress in compression in
| YT | Yield stress in tension in
| YC | Yield stress in compression in
| SC | Maximum shear
stress. (Real) |
- This material law is mapped to /MAT/LAW25 (Iform=1).
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
