*MAT_012 (ISOTROPIC_ELASTIC_PLASTIC)
LS-DYNA Input Interface KeywordDefines an isotropic, elasto-plastic material.
(1) (2) (3) (4) (5) (6) (7) (8)
*MAT_012 or *MAT_ISOTROPIC_ELASTIC_PLASTIC
mat_ID ρ i G SIGY ETAN BULK
Definition
mat_ID Material identifier.
(Integer)
ρ i Initial density.
(Real)
[ kg m 3 ]
G Shear modulus.
(Real)
[ Pa ]
SIGY Yield stress.
(Real)
[ Pa ]
ETAN Plastic hardening modulus.
(Real)
[ Pa ]
BULK Bulk modulus.
(Real)
[ Pa ]
  1. This keyword maps to /MAT/LAW2 (PLAS_JOHNS).
  2. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
