*MAT_120 (GURSON)
LS-DYNA Input Interface KeywordDefines a nonlinear elasto-plastic based on the Gurson constitutive law, which is used to model visco-elastic-plastic strain rate dependent porous metals.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_120 or *MAT_GURSON | |||||||
| mat_ID | E | Nu | A | N | q1 | q2 | |
| fc | fI | N | SN | fN | B | ATYP | fF |
| EPS1 | EPS2 | EPS3 | EPS4 | EPS5 | EPS6 | EPS7 | EPS8 |
| ES1 | ES2 | ES3 | ES4 | ES5 | ES6 | ES7 | ES8 |
| Blank line | |||||||
| LCSS | LCFF | NUMINT | LCF0 | LCFC | LCFN | ||
Definition
| mat_ID | Material
identifier. (Integer) |
| Initial
density. (Real) |
| E | Young's
modulus. (Real) |
| Nu | Poisson's
ratio. (Real) |
| A | Yield stress. (Real) |
| N | Hardening exponent (used only if
ATYP=1 and
LCSS=0). (Real) |
| q1, q2 | Damage material
parameters. (Real) |
| fc | Critical void volume fraction at
coalescence. (Real) |
| fI | Initial void volume fraction.
(Real) |
| N | Nucleated effective plastic
strain. (Real) |
| SN | Gaussian standard
deviation. (Real) |
| fN | Nucleated void volume
fraction. (Real) |
| B | Hardening parameter (used only for
ATYP=2). (Real) |
| ATYP | Hardening type
(Integer) |
| fF | Critical void volume fraction at
ductile fracture. (Real) |
| EPS1 - EPS8 | Plastic strain data
points. (Real) |
| ES1 - ES8 | Yield stress data
points. (Real) |
| LCSS | Stress versus plastic strain curve
or table identifier. (Integer) |
| LCFF | Load curve ID defining critical
void volume fraction at ductile fracture
fF as a
function of element length. 2 (Integer) |
| NUMINT | Element failure rule.
(Integer) |
| LCFI | Load curve ID defining initial void
volume fraction
fI as a
| LCFC | Load curve ID defining critical
void volume fraction at coalescence
fc as a
| LCFN | Load curve ID defining nucleated
fN as a
- This keyword maps to /MAT/LAW52 (GURSON).
- With the current version, only the first ordinate of the curve is used.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
