*MAT_057 (LOW_DENSITY_FOAM)
LS-DYNA Input Interface KeywordDefines an isotropic, visco-elastic, low density foam.
(1) (2) (3) (4) (5) (6) (7) (8)
*MAT_057 or *MAT_LOW_DENSITY_FOAM
mat_ID ρ i E LCID HU Mu
SHAPE
Definition
mat_ID Material identifier.
(Integer)
ρ i Initial density.
(Real)
[ kg m 3 ]
E Young’s modulus.
(Real)
[ Pa ]
LCID Curve identifier which defines engineering stress as function of engineering strain. In compression, the stress and strain are positive. In tension the stress and strain are negative.
(Integer)
HU Hysteresis unloading factor.
Default = 1.0 (Real)
Mu Numerical Navier Stokes viscosity.
(Real)
SHAPE Shape unloading factor.
  1. This keyword maps to /MAT/LAW90.
  2. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
