*MAT_098 (SIMPLIFIED_JOHNSON_COOK)
LS-DYNA Input Interface KeywordDefines an isotropic elasto-plastic material using the Johnson-Cook material model.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_098 or *MAT_SIMPLIFIED_JOHNSON_COOK | |||||||
| mat_ID | E | ||||||
| A | B | N | C | FAIL | SIGMAX | EPS0 | |
Definition
| mat_ID | Material identifier. (Integer) |
| Initial density. (Real) |
| E | Young’s modulus. (Real) |
| Poisson’s ratio. Default = 0 (Real) |
| A | Yield stress. (Real) |
| B | Hardening coefficient. (Real) |
| N | Hardening exponent. (Real) |
| C | Strain rate coefficient. (Real) |
| FAIL | Plastic strain to failure. (Real) |
| SIGMAX | Maximum stress limit. (Real) |
| EPS0 | Reference strain rate. (Real) |
- This keyword maps to /MAT/LAW2.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
