*MAT_077_H (HYPERELASTIC_RUBBER)
LS-DYNA Input Interface KeywordDefines an isotropic, hyperelastic, viscous, and incompressible material specified from uniaxial experimental data.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_077_H or *MAT_HYPERELASTIC_RUBBER | |||||||
| mat_ID | |||||||
If N = 0
| C10 | C01 | C11 | C20 | C02 | C30 |
If N > 0
| SGL | SW | ST | Fct_ID |
In all cases, add up to 12 lines.
| Gi | i |
Definition
| mat_ID | Material
identifier. (Integer) |
| Initial
density. (Real) |
| Poisson’s ratio. Default = 0.495 (Real) |
| C10, C01, C11, C20, C02, C30 | Shear hyperelastic modulus
parameter. (Real) |
| SGL | Specimen gauge length. | |
| SW | Specimen width length. | |
| ST | Specimen thickness. | |
| Fct_ID | Force versus gauge length function identifier.
(Integer) |
| Gi | Shear modulus for relaxation. | |
| i | Decay constant for relaxation. |
- This keyword maps to /MAT/LAW59 (CONNECT) (if N = 0) or /MAT/LAW69 (if N > 0) and /VISC/PRONY in case when Prony coefficients are available.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
