*MAT_S04 (SPRING_NONLINEAR_ELASTIC)
LS-DYNA Input Interface KeywordDefines a nonlinear elastic spring material.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*MAT_S04 or *MAT_SPRING_NONLINEAR_ELASTIC | |||||||
mat_ID | LCL | LCR |
Definition
mat_ID | Material identifier. (Integer) |
LCL | Curve identifier for force versus displacement or moment
versus rotation. (Integer) |
or |
LCR | Curve identifier for the scale factor of force versus
elongation velocity or moment versus rotational
velocity. (Real) |
- This keyword maps to /MAT/LAW108 (SPR_GENE).
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
