*MAT_076 (GENERAL_VISCOELASTIC)
LS-DYNA Input Interface KeywordDefines an isotropic, visco-elastic material. It is generally used to model incompressible elastomers.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_076 or *MAT_GENERAL_VISCOELASTIC | |||||||
| mat_ID | K | ||||||
| LCIDG | N | LCIDK | |||||
Optional lines:
| GI | BETAI | KI | BETAK |
Definition
| mat_ID | Material
identifier. (Integer) |
| Initial
density. (Real) |
| K | Bulk
coefficient. (Real) |
| LCIDG | Function for shear modulus from
relaxation test as function of time. (Integer) |
| N | Number of terms in fitting
relaxation test. (Integer) |
| LCIDK | Function for bulk modulus from
| GI | Ith shear modulus in Prony series. | |
| BETAI | Ith decay coefficient Prony series for shear. | |
| KI | Ith bulk modulus in Prony series. | |
| BETAK | Ith decay coefficient Prony series for bulk. |
- This keyword maps to /MAT/LAW42 (OGDEN) + /VISC/PRONY and is compatible with shell and solid elements.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
