*MAT_124 (PLASTICITY_COMPRESSION_TENSION)
LS-DYNA Input Interface KeywordDefines an isotropic elasto-plastic material with tension and compression yield stress curves as a function of plastic strain.
Rate effects are modeled by Cowper-Symonds models or by curves. Additional viscosity can be defined by Prony series Maxwell model.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_124 or *MAT_PLASTICITY_COMPRESSION_TENSION | |||||||
| mat_ID | E | C | P | FAIL | |||
| fct_IDc | fct_IDt | Frate_IDc | Frate_IDt | VP | Fct_LCFAIL | Ec | RPCT |
| P_c | P_t | PCUTF | F_smooth | ||||
| Kv | |||||||
| Gi | BETAi | ||||||
Definition
| mat_ID | Material
identifier. (Integer) |
| Initial
density. (Real) |
| E | Young’s
modulus. (Real) |
| Poisson’s ratio. Default = 0 (Real) |
| C | Cowper-Symonds strain rate
coefficient. (Real) |
| P | Cowper-Symonds strain rate
exponent. (Real) |
| FAIL | Plastic strain to
failure. (Real) |
| fct_IDc | Curve identifier for compression
yield stress. (Integer) |
| fct_IDt | Curve identifier for tension yield
stress. (Integer) |
| Frate_IDc | Curve identifier defining the
scaling coefficient for compression yield
stress. (Integer) |
| Frate_IDt | Curve identifier defining the
scaling coefficient for tension yield
stress. (Integer) |
| VP | Strain rate formulation flag.
(Integer) |
| Fct_LCFAIL | Curve identifier defining plastic
strain at failure as a function of strain
rate. (Integer) |
| Ec | (Optional) Compression Young’s
modulus. (Real) |
| RPCT | Scale factor used on
P_c and P_t.
(Real) |
| P_c | Limit pressure in
compression. (Real) |
| P_t | Limit pressure in
tension. (Real) |
| PCUTF | Pressure limit activation flag.
No default (Integer) |
| F_smooth | Exponential moving average strain
rate filtering value (defined between 0 and
1). (Real) |
| Kv | Viscous bulk
modulus. (Real) |
| Gi | Shear relaxation
modulus. (Real) |
| BETAi | Shear decay
constant. (Real) |
- This keyword maps to /MAT/LAW66, /VISC/PRONY and failure model (/FAIL).
- This material can be used for shell or solid elements.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
