*MAT_111 (JOHNSON_HOLMQUIST_CONCRETE)
LS-DYNA Input Interface KeywordDefines a material law that is based on the theory of Johnson-Holmquist-Cook model theory (also called Johnson-Holmquist-Concrete).
It is proposed and designed for a concrete application. In this model, the spherical and deviatoric behavior are separated. It considers the effect of damage and strain rate sensitivity.
(1) (2) (3) (4) (5) (6) (7) (8)
*MAT_111 or *MAT_JOHNSON_HOLMQUIST_CONCRETE
mat_ID ρ i G A B C N FC
T EPS0 EFMIN SFMAX PC MUC PL MUL
D1 D2 K1 K3 K3 FS
Definition
mat_ID Material identifier.
(Integer)
ρ i Initial density.
(Real)
[ kg m 3 ]
G Shear modulus.
(Real)
[ Pa ]
A Normalized cohesive strength.
(Real)
B Normalized pressure hardening modulus.
(Real)
C Strain rate coefficient.
= 0 (Default)
No strain rate effect.
(Real)
N Pressure hardening exponent.
(Real)
FC Quasi-static uniaxial compressive strength.
(Real)
[ Pa ]
T Maximum hydrostatic tensile pressure.
(Real)
[ Pa ]
EPS0 Reference strain rate.
Default = 1.0 (Real)
[ 1 s ]
EFMIN Minimum fracture strain.
Default = 10-20 (Real)
SFMAX Maximum normalized strength.
Default = 1020 (Real)
PC Crushing pressure.
(Real)
[ Pa ]
MUC Crushing volumetric strain.
(Real)
PL Locking pressure.
(Real)
[ Pa ]
MUL Locking plastic volumetric strain.
(Real)
D1 Damage parameter.
(Real)
D2 Damage exponent.
(Real)
K1 Linear bulk stiffness.
(Real)
[ Pa ]
K2 Quadratic bulk stiffness.
(Real)
[ Pa ]
K3 Cubic bulk stiffness.
(Real)
[ Pa ]
FS Failure type.
< 0
Failure when σ y 0 MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeaaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aaS baaSqaaiaadMhaaeqaaOGaeyizImQaaGimaaaa@3B5B@
= 0 (Default)
Tensile failure when P * + T * 0 MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeaaciGaaiaabeqaamaabaabaaGcbaGaamiuamaaCa aaleqabaGaaiOkaaaakiabgUcaRiaadsfadaahaaWcbeqaaiaacQca aaGccqGHKjYOcaaIWaaaaa@3CBE@
> 0
Failure when critical plastic strain is reached ε p >FS MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeaaciGaaiaabeqaamaabaabaaGcbaGaeqyTdu2aaS baaSqaaiaadchaaeqaaOGaeyOpa4JaamOraiaadofaaaa@3B72@
(Real)
  1. This keyword maps to /MAT/LAW126 (JOHNSON_HOLMQUIST_CONCRETE).
  2. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
