*MAT_183 (MAT_SIMPLIFIED_RUBBER_WITH_DAMAGE)
LS-DYNA Input Interface KeywordDefines an incompressible rubber material with uniaxial tensile/compression test results as input curve. Unloading damage curve can be specified.
This material can be used with solid elements only.
(1) (2) (3) (4) (5) (6) (7) (8)
*MAT_183 or *MAT_SIMPLIFIED_RUBBER_WITH_DAMAGE
mat_ID ρ i K MU
Length Wide Thick Table_ID Tension
Optional card 1: unloading behavior
Fct_unl
Definition
mat_ID Material identifier.
(Integer)
ρ i Poisson ratio.
(Real)
[ kg m 3 ]
K Bulk modulus.
(Real)
[ Pa ]
MU Navier-Stokes damping coefficient.
Length Specimen gauge length.
(Real)
[ m ]
Wide Specimen gauge width.
(Real)
[ m ]
Thick Specimen gauge thickness.
(Real)
[ m ]
Table_ID Curve or table ID defining the force versus gauge length and the different strain rate value defined in the table.
(Integer)
Tension Unloading rate effects option flag.
= -1
Unloading in tension follows the quasi-static unloading curve; unloading in compression follows the loading strain rate dependent curves.
= 0 (Default)
Unloading follows the quasi-static unloading curve.
= 1
Unloading follows the loading strain rate dependent curves and the unloading curve is not used.
(Integer)
Fct_unl Unloading curve ID.
(Integer)
  1. This keyword maps to /MAT/LAW88 for the hyperelastic materials.
  2. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
