*MAT_062 (VISCOUS_FOAM)
LS-DYNA Input Interface KeywordDefines an open-celled urethane foam material used for the ribs of a Euro-SID side impact dummy. Only available for solid.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_062 or *MAT_VISCOUS_FOAM | |||||||
| mat_ID | E1 | N1 | V2 | E2 | N2 | ||
Definition
| mat_ID | Material identifier. (Integer, maximum 10 digits) |
| Initial
density. (Real) |
| E1 | Young’s
modulus. (Real) |
| N1 | Exponent in power law for Young’s
modulus. Default = 1.0 (Real) |
| V2 | Viscous
coefficient. (Real) |
| E2 | Elastic modulus for
viscosity. (Real) |
| N2 | Exponent in power law for
viscosity. (Real) |
| Poisson ratio. (Real) |
- This keyword maps to /MAT/LAW134 (VISCOUS_FOAM).
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
