*MAT_001_FLUID (ELASTIC_FLUID)
LS-DYNA Input Interface KeywordDefines an isotropic, linear elastic material using Hooke’s law.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_001_FLUID or *MAT_ELASTIC_FLUID | |||||||
| mat_ID | K | ||||||
| Pmin | |||||||
Definition
| mat_ID | Material
identifier. (Integer) |
| Initial
density. (Real) |
| K | Fluid bulk
coefficient. (Real) |
| Pmin | Cavitation pressure cut
off. Default = -1.0*1020 (Real) |
- This keyword maps to /MAT/LAW6 (HYDRO or HYD_VISC) and /EOS/LINEAR.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
