*MAT_ADD_THERMAL_EXPANSION
LS-DYNA Input Interface KeywordUsed to add thermal expansion property for material.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_ADD_THERMAL_EXPANSION | |||||||
| part_ID | fct_IDTx | Fscalex | fct_IDTy | Fscaley | fct_IDTz | Fscalez | |
Definition
| part_ID | Part
identifier. (Integer) |
| fct_IDTx | Function identifier to define the
instantaneous thermal linear expansion coefficient in:
(Integer) |
| Fscalex | Ordinate scale factor for thermal
expansion coefficient function
fct_IDTx. Default = 1.0 (Real) |
| fct_IDTy | Function identifier to define the
Default = fct_IDTx (Integer) |
| Fscaley | Ordinate scale factor for thermal
fct_IDTy. Default = Fscalex (Real) |
| fct_IDTz | Function identifier to define the
| Fscalez | Ordinate scale factor for thermal
fct_IDTz. Default = Fscalex (Real) |
- This keyword maps to /THERM_STRESS/MAT.
