SPCCHARGE
I/O Options and Subcase Information Entry Used to request single-point charge of constraint output for electrostatic subcases or piezoelectric analysis.
SPCCHARGE = option
Definition
| Argument | Options | Description |
| format | <H3D, blank> Default = blank |
| option | <YES, ALL,
NO, NONE,
SID> Default = ALL |
- When an SPCCHARGE command is not present, single-point charge of constraint is not output.
- Single-point charge of constraint values are highly dependent on mesh density and type of elements used.
- When single-point charge of constraint is calculated, the reaction charge summary and the applied charge summary for the affected subcases are written to the .out file.
- Only H3D format is available for SPCCHARGE. See Results Output by OptiStruct for information on the results available and their respective formats.
- Multiple instances of this card are allowed. If instances are conflicting, the last instance dominates.
