ACPVELO
I/O Options and Subcase Information Entry Used in the I/O Options section or in frequency response (direct and modal) subcases to request particle velocity at the fluid grids.
ACPVELO (format) = option
Argument Options Description
format <H3D, PCH, blank>
H3D
Results are output in Hyper3D format (.h3d file).
PCH
Results are output in Punch format (.pch file).
Blank (Default)
Results are output in all active formats for which the result is available.
option <YES, ALL, NO, NONE, SID>
YES, ALL (Default)
Velocity is output for all acoustic grids.
NO, NONE
Velocity is not output.
SID
If a set ID is given, the particle velocity is output only for the fluid grids listed in that set.
