ELECFIELD
I/O Options and Subcase Information Entry Used to output electric field results in electrical analysis.
ELECFIELD (format) = option
Definition
Argument Options Description
format <H3D, blank>
Default = blank
H3D
Results are output in Hyper3D format (.h3d file).
blank
Results are output in all active formats for which the result is available.
option <YES, ALL, NO, NONE, SID>
Default = ALL
YES, ALL, blank
The electric field result is output for all the elements in the model.
NO, NONE
The electric field result is not output.
SID
If a set ID is given, the electric field result is output only for elements listed in that set.
  1. Electric field results are supported for both first and second order shell and solid elements, but not for gap/contact elements.
