I/O Options EntryDefines an assembly of parts which are included in the global model.
(1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
ASSEMBLY |
GLOBNAME |
(1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
ASSEMBLY |
Global1 |
Field |
Contents |
SI Unit Example |
ASSEMBLY |
Activates the creation of
an assembly of parts. |
GLOBNAME |
Name of the assembly
should match the name of the global part in the Bulk Data
section. (Character String) |
- If an ASSEMBLY entry is
input in the model, then a minimum of one INSTANCE I/O
Options Entry should be present.
- Only one ASSEMBLY entry
can be present in a model.
- When
ASSEMBLY entry is present, the reading of the Bulk Data
section is different.
- Without ASSEMBLY entry, each part defined in the input
deck is used in the model.
- When ASSEMBLY/INSTANCE entries are
present, each part named on ASSEMBLY and
INSTANCE entries are used, potentially multiple
times, and parts with unknown names (which are not listed on any
ASSEMBLY/INSTANCE cards) are
skipped.
