DESGLB
I/O Options and Subcase Information Entry The DESGLB command can be used in the I/O Options section, before the first subcase statement, to select a constraint set that is not subcase dependent.
DESGLB = integer
Argument Options Description
integer < SID >
No default
SID
Set identification of a DCONSTR or DCONADD Bulk Data Entry.
  1. The constrained response referenced by the DESGLB constraint selection must not be subcase dependent.
  2. Only one DESGLB entry can be defined in the I/O Options section for the entire model.
  3. This entry is represented as an optimization constraint in HyperMesh.
